If you are posting class assignments and getting it done by others, it is unfair practice. However, if you are unable to understand some concepts, it is fine to ask here.
making a graph, x will be an infinte alternating [... -1 1 -1 1 ...] with 1 for n=0
h will be, instead, zero up to n = -2, then will be [0.5 1 2 4 8 16 32 ....] with 0.5 for n=-1
To perform the convolution we have to flip and shift in time one of the two functions. Here it esasier to flip x because it will remain exactly the same (it's an even function). For n=0 we will have no shift of x the we will obtain the sum:
0.5 - 1 + 2 - 4 ...... --> infinite
shifting by one:
-0.5 + 1 - 2 + 4 ...... --> infinite
then it will diverge. I think there should be a typo in the book. If we substitute 2^n with 2^(-n) the previous sums will converge to:
in this case the solution is 4/3*(-1)^n
in order to have the factor 8/3 we'll need the step function starting from n=-2 instead of n=-1 that is u[2n+4]
