How to compute derivatives of discrete data in Matlab?
smithchart
Member level 5
Member level 5
matlab derivative of data
Hello:
I need to compute derivatives of complex discrete data in Matlab, anyone here can tell me how to perform it? (Build-in functions?)
For example, I have the following frequency dependent data:
f X
f1 x1-jy1
f2 x2+jy2
f3 x3-jy3
Where fi,xi and yi are real numbers with particular value. How should I compute
f*dx/df in matlab?
Thanks in advance.
matlab discrete derivative
cant you use diff instruction and then use array multiplication?
brmadhukar
discrete derivative matlab
Hello, brmadhukar:
Thank you for your reply.
The function diff() in matlab can only operate on real number arrary. Initially I had thought that the we cannot deal with complex number the same way we with the real number, thus posted the help here.
Later, I searched some materials on this topic and found that as long as one of the variable is real(here in my case is frequency:f), the finite difference that apply to real numbers still can apply to complex number(effectively treat real part and imaginary part of the complex number separately).
Thus, I can approximate dX/df=diff(X)./diff(f) assuming X is complex discrete data and the result will have a array length of (n-1), assuming the original array X has a length of n.
Regards,
