I have VHDL project that implemented by someone late.
with no comments or documentation
the project folder includes
1- VHDL files
2- files with extension .pin ( contains VHDL entity code)
3- files with extension .sar ( Contains VHDL Arch; code)
4- files with extension .e
5- files with extension .save
6- Work library
i created new project in modelsim and added all files and library to the project
NOW the Problem is
1- how to compile these .pin or .sar files by modelsim. or which tool should i use to
compile? (by the way i can see these files names in WORK libray but don't know how to compile)
2- what is the best way/tools to understand this design, so i can solve the bugs in
it?
also how to link specman to modelsim, who should call the other
should specman call modelsim or modelsim calls specman?
For Modelsim you can use
vcom -work work ( this is the lib u mapped as working library) <filename>
2) To integrate with specman .
- u need add FLI component in Top level testbench
- u need to creata stub using specman
- then call "specsim vsim" or "sepcview vsim"
- Modelsim sim calls specman
