mike_bihan said:Why not use PZ analysis to help you? Just move the PZ to where you need.
They are almost independent of each other. ( i acknowledge that the miller cap also add up loading to next stage, but it should be ignorable due to the high gain and thereby the low cap value.)
electronrancher said:The best way to utilize this is with the highest gain in the first stage - now it's no contest! 1st stage compensation dominates all the way out. This archetecture is natural for micro to macro.
Stage 1 - hi-gain diff amp. Extract tiny microphone signal, tiny optoisolator signal, tiny Isense signal. Hi gain=very fast. Compensate here for best effect.
Stage 2 - mid gain, mid power - although slower than 1st stage, the compensation added back there multiplies through to ensure stability for free here.
Stage 3 - high power output. Slowest, but any noise injected here by a big load will be rolled off by the 1st stage compensation in unity gain mode.
Try that.
