pusparaga
Full Member level 4
I want to combine power of two or three stage Power Amplifier (PA) using Microstrip Lange-Coupler using ADS -2022. As you know, there are four ports in Microstrip Lange-Coupler (LC)(I-Input, 2-Through, 3-Coupled and 4-Isolated). Where I have to use Lange-Coupler and How to use the same. Do we need to use LC at the input and output or while joining two stage. I am getting confused which port should be connected to where.
I am getting maximum output from single satge using single transistor is 28 dBm. How to place two stages, shall we place parallel or cascade because I am using 0.15 um GaN HEMT single transistor for single stage. If we connect it in parallel manner, will transistor sustain power more than 1 Watts. If I use two or three stages cascade manner, is it ok.
