zereshki
Member level 1
Hi to all,
In hyperlynx, how can I combine 2 separate pin as 1 component, like R, IC, C, terminal or ... .
in other words I want to merge H1 and H3 pins (atached photo) as one components.
At the moment, this pins are 2 separate pads(in hyperlynx are as pin) for out put of power supply.
The pcb file is imported from eagle.
thank you in advaced
