How to code and compile C using QNX?
jetset
Full Member level 3
Full Member level 3
Panama
Where can I find a guide to learn how to code and compile C using QNX? I'm not new for C programming but new for QNX so I don't know this kind of system very well =(
Re: Need help on QNX
Here you go
h**p://www.qnx.com/, look into developer support center and download center
Hi, Jetset
well for working on Qnx i suggest that you download Qnx Momentics but do it for QNX Host as then you will be able to set your host as well as target, this will help you in debugging you application
what you will nedd to do is configure your host and target on same PC x86 machine and then start writing application and also debugg them
but first download the iso from https://www.qnx.com/download/group.html?programid=9524 and download
QNX Momentics 30-day Eval - QNX Neutrino x86 Host install on fresh pc and
then go get jetset
Regards
The best way to start with QNX programing is to read a book
"Getting Started with QNX/Neutrino 2" by Rob Krten.
The book is realy good and helpfull
