how to close LSW window
drabos
Full Member level 6
how to close lsw in cadence
Does anybody know how to close LSW window in cadence, it is a well known bug?
But a SKILL command can close it, anybody knows?
close lsw window
Remove the LSW from the screen
leUnmapLSW()
Restore the LSW to the screen
leRemapLSW()
Historically this window could not be removed because it was always a reference to the layers in the current window. If you remove the LSW with leUnmapLSW you will need to restore it if you require it for another layout window. The system will not restore the LSW when a new layout window is opened. You will need to use leRemapLSW.
