how to choose transformer for power supply design
kupper
Junior Member level 1
Hello,
I have a question on transformer selection for liner voltage regulator type powersupply circuit.
What is VA rating for a transformer? Is it true that if the VA is too big the transformer will heat up and waste alot of energy?
I setting up a ps circuit using 7805, 5V output about 200mA~300mA load.
Transformer input is 230V pri, around 13 or 18V on the secondary without load.
Appreciate any help and comments.
Regards,
Nev
Choose a transformer with secondary rating as follow: voltage ≈8-10V ac @ 500mA.
Bigger transformer, if physical size is not an issue, wouldn't heart, and it will not overheat because you don't draw rated current; it is opposite way around - if you select transformer with to small VA rating it will overheat.
Also to help you to select transformer-rectifier configuration, attached you will find "rectifier relationships" ..
Regards,
IanP
Thanks for the pointer IanP, Will look into it :D
