How to choose proper feedback for power supply stability?
wossy
Junior Member level 2
slup068
Hi
I am designing a linear bench supply which consists of a comparator, some power mosfets and a diff amp which measures the output and then feeds the voltage back to the comparator. My problem is that the loop is unstable and I know I have to place some feedback around the comparator to compensate the circuit. I need to know how to analyse the circuits frequency response so that I can choose the correct feedback elements. I need to do this cheeply without the aid of any expensive test equipment
Thanks
Re: Power Supply Stability
Use an ordinary op amp instead of the comparator. This will make the system loop gain more linear. Then you can brute force the stability by putting a capacitor across the op amp inverting input to output.
Usually if you put a very low pole on the error amplifier you obtain a stable closed response (dominant pole compensation) but the transient performance will be also very poor.
Pls ref :
This post has been moderated by davorin.
Action: Attachment deleted
Reason: Available at: https://focus.ti.com/lit/ml/slup068/slup068.pdf
Note: Please read rules before posting or uploading
Change the comparitor for an opamp and decouple the feedback loop. Make sure the opamp is being biased correctly. Make sure that there is always a load on the output ( use a resistor 4.7kohms).
Barrybear
