achilles.wang
Newbie level 6
As you know, if you should design a good controll sysytem, you must keep the sysytem stable at first and then you will use frequency compentstion technology for better performance. you choose some compensated parameters,just the value of C, R and so on, later you use simulation and get the loop gain-phase figure, then, you decide which case is the best one. Do you realy do so? But the fact is always different with the simulation, how can you be sure that your design have a good real performance. I do not know how to design a good loop.......
