Leo66
Newbie
I'm recently measuring a DC current signal, and planning to set a TIA (transimpedance amplifier) to convert the current into a DC voltage signal, so can be read out by an ADC. The sampling frequency of the ADC can be really fast compared with the signal bandwidth. 2MHz or higher in my design, 0.5ms time for readout, which corresponding to 1kHz signal BW, and OSR can be 1k or more. My target SNR is >70dB (only noise here, distortion is not concerned) but I can not design a 12-bit ADC because of other reasons.
It confused me about how to choose the resolution of ADC by the following two reasons:
1. Since OSR is 1k, a 7-bit (42dB) ADC at 2MHz is enough, and 70dB can be achieved by averaging filtering.
2. Filtering is based on which signal swings large enough, so quantization error can be considered random as white noise. But DC means the quantization error is fixed, so the result of averaging remains the same, will the filter still working?
The two reasons are confilct, and I'm prone to 2., averaging is futile.
BUT, But, but, TIA also carries noise, and total integrated noise from 0.5-1kHz is low enough, but 0.5-1MHz is quite large. So the voltage send to ADC is a DC signal+AC noise. will the noise from TIA makes the quantization error of ADC more random? So the situation is closer to 1., i.e. averaging can be applied here?
