How to check via is closed by solder mask or not by using Allegre free physical Viewer
hioyo
Full Member level 1
Dear Team,
I am reviewing a layout using allegro-free physical viewer.
I told the layout person to close the via using a solder mask.
How I would check whether it is done or not using the allegro free viewer.
Below is the pic of two vias my board.
Solution
Turn on the soldermask layer, what you see is what you not get!
iow, in most cases soldermak is show as a negative layer, you see the openings in the mask
