rynxysh
Junior Member level 2
- Joined
- Nov 4, 2009
- Messages
- 23
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- KL,Malaysia
- Activity points
- 1,439
referred on the title,please save me on this basic theory~XD:grin:
That article is wrong. There is a lot of bad information on that website.To test a transistor using a digital multimeter, all you have to do is check the resistances of the diode junctions of the transistor, as illustrated here, http://www.learningaboutelectronics.com/Articles/How-to-test-a-transistor.
There is a diode junction between base and emitter, and between base and collector, but there is no diode junction between collector and emitter.Measure each of the pairs of diode junctions, Collector-emitter, collector-base, base-emitter. Read the resistance of one junction and then switch the polarity by switching the probes around.
To test a transistor using a digital multimeter, all you have to do is check the resistances of the diode junctions of the transistor, as illustrated here, http://www.learningaboutelectronics.com/Articles/How-to-test-a-transistor. Measure each of the pairs of diode junctions, Collector-emitter, collector-base, base-emitter. Read the resistance of one junction and then switch the polarity by switching the probes around. One side should read very high resistance, over 1 megohms. And the other should read a moderate resistance, a few hundred thousand ohms. If this is the case for all three junctions, the transistor should be a good working one.
