How to check the randomness of bits from RNG?
masai_mara
Full Member level 1
verifying randomness??
I have designed a hardware module for random number generation. The ouput is a single bit. Is there a way of checking for the randomness of the bits coming out. I tried to plot a curve of its distribution but its becoming too tedious with a huge set of values. Any suggestions are welcome.
Hello,
Please see the following, I think it could be usefull.
Best regards
Re: verifying randomness??
Hi there,
Thanks for the info, I will check it out.
The autocorrelation should be zero for all offsets.
The Fourier transform should show equal energy at all frequencies.
histogram is usefull
If the generator is used for DSP purposes
then you would better to calculate the autocorrelation function
of the output bit stream.
For the N*N random sample array you will get the autocorrelation
which peak is in ~N times higher than another autocorrelation samples.
