How to check internal RAM for debugging in Keil ?
Noman Yousaf
Full Member level 4
Full Member level 4
Lahore Pakistan
KIEL PROBLEM
HELLO EVERY ONE
I AM USING KIEL 7.01
THE PROBLEM IS WHAEN I DEBUG THE SOFTWARE I OPEN PERAPHELER WINDOW FOR WATHCING I/O PORTS, TIMER ETC BUT I CAN'T FIND INTERNAL RAM WINDOW.
HOW CAN I CHECK INTERNAL RAM FOR DEBUGING?
THANKS IN ADVANCE
Re: KIEL PROBLEM
Sorry read this
"The memory window is in the middle of the screen, at the bottom. You can display memory ranges here. Click on one of the memory tabs (Memory #1, for example) and type "X:5000H" in the textbox labelled "Address:". This tells uVision2 to start displaying e"X"ternal memory at address 5000H. You could also show "C"ode memory with C:address, internal "D"irect memory with D:address, and internal "I"ndirect memory with I:address."
SphinX
Re: KIEL PROBLEM
This is description Memory Window from help for Keil uVision2 :
"The Memory window displays the contents of the various memory areas. Up to four different areas can be review in the different pages. The context menu allows you to select the output format.
In the Address field of the Memory Window, you can enter any expression that evaluates to a start address of the area you want to display. To change the memory contents, double click on a value. This opens an edit box that allows you to enter new memory values. To update the memory window while a target program is running enable View – Periodic Window Update."
