Deviousdexter
Junior Member level 1
i have recently been playing around wiht WLED and an esp32-c3 Super Mini. It was working fine and everything seemed correct. I soldered a bank of 4 pins ontoj the board to cover power and data ( spare pin in between but did see the need to remove). This is not touching anything else and has since been removed as precaution. The board seems to get very warm, even when only idling ( well, running WLED anyway). It is drawing around 100mA which i think is a little high for current load, but am not sure how to check if something is wrong, any pointers please ?
It re-writes ok from USB, i can see the wireless AP but have trouble connecting - not sure if this is a distance thing - sometimes there is no AP until i switch off wireless on the laptop and switch on again.
I re-flashed, reconnected and drop on an 8 x 8 ws2812b matrix but it appeared to be showing a randon pattern and ignoring anything done in WLED including the Power button. I have had the matrix working before and it did what it is supposed too ( as far as i know).
any help appreciated.
