You need to review or study a C++ text.
Code C++ - [expand] |
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
| #include<iostream>
#include<cmath>
using namespace std;
class Bisection
private:
float f, x;
public:
float fx1,x1,x2,x3;
int count, iter;
public:
float func(float x)
float fx1;
fx1 = pow(x,3) - pow(x,2) + (1.4*x) + 7.8;
return (fx1);
void getInput()
cout <<"Enter x1 = ";
cin >> x1;
cout <<"Enter x2 = ";
cin >> x2;
cout <<"Enter number of iterations = ";
cin >> iter;
void calcResult()
do
if(count == iter)
break;
x3 = (x1 + x2)/2;
cout << endl << "x1 = " << x1 <<" | x2="<< x2 <<" | x3=" << x3 <<" | " << " f(x1)=" << func(x1) << " | f(x2)=" << func(x2) << " | f(x3)=" << func(x3) << endl << endl;
//float temp1 = f(x1);
//float temp2 = f(x3);
if( func(x1) * func(x3) < 0 )
x2 = x3;
else
x1 = x3;
count++;
}while ( abs(x1 - x2) < 0.0000001 || func(x3) == 0 );
int main(void)
Bisection bisect;
bisect.getInput();
bisect.calcResult();
return 0;
Compiles without warnings or errors, produces the following when ran:
Enter x1 = 9
Enter x2 = 5
Enter number of iterations = 100
x1 = 9 | x2=5 | x3=7 | f(x1)=668.4 | f(x2)=114.8 | f(x3)=311.6
Hope the above example points you in the right direction.
BigDog
Alternatively, you could define the func() method as private, if you wish to restrict its use to within the class.
Or you could define the methods as static, which would alleviate the need to instantiate a Bisection object before utilizing the methods.
And, if you wish to retain the input and output tasks within main(), you can utilize the same class as so:
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
| #include<iostream>
#include<cmath>
class Bisection
private:
float f, x;
public:
float fx1,x1,x2,x3;
int count, iter;
public:
float func(float x)
float fx1;
return (fx1);
public:
void getInput()
cin >> x1;
cin >> x2;
cin >> iter;
void calcResult()
do
if(count == iter)
break;
x3 = (x1 + x2)/2;
cout << endl <<"x1 = " << x1 <<" | x2="<< x2 <<" | x3=" << x3 <<" | " << " f(x1)=" << func(x1) << " | f(x2)=" << func(x2) << " | f(x3)=" << func(x3) << endl << endl;
x2 = x3;
else
x1 = x3;
count++;
int main(void)
Bisection bisect;
cin >> bisect.x1;
cin >> bisect.x2;
cin >> bisect.iter;
do
if(bisect.count == bisect.iter)
break;
bisect.x3 = (bisect.x1 + bisect.x2)/2;
cout << endl <<"x1 = " << bisect.x1 <<" | x2="<< bisect.x2 <<" | x3=" << bisect.x3 <<" | " << " f(x1)=" << bisect.func(bisect.x1) << " | f(x2)=" << bisect.func(bisect.x2) << " | f(x3)=" << bisect.func(bisect.x3) << endl << endl;
if( bisect.func(bisect.x1) * bisect.func(bisect.x3) < 0 )
bisect.x2 = bisect.x3;
else
bisect.x1 = bisect.x3;
bisect.count++;
while ( abs(bisect.x1 - bisect.x2) < 0.0000001 || bisect.func(bisect.x3) == 0 );
return 0;
Same results, compiled without warnings or errors:
Enter x1 = 9
Enter x2 = 5
However, in the example above, you will need to ensure the func() remains public so as to provide access to it from within main().
BigDog
