How to change the x-axis in Spectre
desperado0729
Newbie level 6
Newbie level 6
I want to get the plot like this:
x-axis is Vov
y-axis is gm/Id.
How should i do spectre?
Thanks!
x-axis is Vov
y-axis is gm/Id.
Thanks!
also have the same problem with you :)
you can plot two graphs in the same window first.
example:AvsC and BvsC
then you double click the x axis-C, you can find a option"plot with...".
then you can plot AvsB
I hope it will help you
Hi, sunbeam
Your method is the right way to get that plot. but it doesn't work in the old version of spectre. Sign~
How about try running simulation by sweep Vov?
For example: run DC simulation and sweep variable Vov.
