Is this a resistor for a PDK library or analogLib?
for a PDK) make a copy of the foundry models and edit it
for analogLib) there is a field in the CDF for this
In addition, if you are using an ideal resistor from analogLib, press "q" or "shift+q" and the properties windows will appear. (Or select the resistor and go to menu edit - properties) There, you can define TC1 and TC2.
Regards,
