I found some interesting utilities in **broken link removed**,
but I didn't test them yet. There are programs to diagnostic and configuration of ethernet cards
Thanks but your answer but that solution works to Windows only.
I tested changing the hardware address of a Realtek8139 in Windows2000, the system apparently change the address but that is a software solution, Its windows who manage the new address, If you restart the machine in Linux you wont see any change.
Now, if you use the diag utils from www.scyld.... on Linux system, the program re-write the eeprom really, this solution work well.
2. Here, add a new string "NetworkAddress" and make its value the desired MAC address.
3. Reboot.
Notes:
On reboot the network card NDIS3 driver will look in a certain place in the registry
for a key named "NetworkAddress". If it doesn't find one, it pulls the MAC network
address from the EEPROM on the network card. This is what normally happens.
You are not changing the MAC address stored in the card's EEPROM, but for all
practical purposes the system has a new MAC address. Only you and the network card
driver will know the difference.
Most network cards NDIS3 drivers will support this feature. 3COM and Intel drivers do.
Use WinIPcfg.exe in the Windows subdirectory to check your currently assigned MAC.
The MAC address is a 12-digit hexidecimal number. Also known in FlexLM circles
as the host ID
Changing the Ethernet MAC Address on Windows NT/2000 Systems
1. In the Control Panel, select "Network and Dial-up Connection" and "Local Area Connection",
Change "Properties\Configure\Advanced".
2. Here, change "Network Address" and enter value the desired MAC address.
3. Reboot.
Notes:
as the host ID.
