How to change the hole size of pad in Orcad Layout?
carrier
Full Member level 5
Full Member level 5
Iran
hi
anyone know that what i can change the hole size of pad in orcad layout?
thanks
Orcad layout problem
try to change the settings from the spread sheets >> pad stacks.
that if i still rememmber as i didnot use it from long time.
Re: Orcad layout problem
the question is not clear to me.can u tell me your problem clearly bcoz i hv worked on OrCAD layout...so i try to hlp u
regards
i want to change hole size of pad in orcad layout
hi
select the pin whose hole size u want to change...then goto padstacks it will the highlight the particular hole's pad sizes there u can change the attributes.
regards
