How to change the display of metal layers in ICFB?
wenchen
Junior Member level 1
I want to change the stipple style of the metal layer from "dots" to "solid", but I cannot find the configuration file that I need to modify. Can anyone tell it which file I should change?
Thanks!
Hi,the display(colors or styles )of each layer in icfb is controled by the drf file.
you can edit the drf file of you library then load it to your design again.
here is a drf file sample
Waaao, my first "helped"!!!
O(∩_∩)O~ it's my pleasure to give you a hand .
