How to change the axes in the plot figure in Matlab?
mos33
Junior Member level 1
hi all
i need to change the axes in the plot figure instead of 1,2,3,......
to pi,2pi,3pi,.....
how can i do that??
Re: matlab question
I think there is no way to do that,
probably you must show 1, 2, 3, ... and then in the label of axis, mention that the values must be x(pi)...
Re: matlab question
use the following:
x = 0:pi/20:2*pi;
plot(x,sin(x))
set(gca,'XTick',0:pi/2:2*pi)
set(gca,'XTickLabel',{'0','pi/2','pi','3/2*pi','2*pi'})
Re: matlab question
Hi
Follow these steps:
1. In the plot figure go to:
Edit -> Axes Properties...
2. Press Ticks button.
3. On the Labels Column type your favorites labels such as: pi, pi1, ...
4. Press OK and close <Property Editor>.
matlab question
For changing the axes in the plot figure,
Go to plot window
go to Edit and then select the Axis Properties and press ticks buttons where you want on the labels type whatever you want.
And pres Ok and close the property editor
Re: matlab question
So why do you kvsm2k just repeat the answer from amir_h?
Re: matlab question
thanks all
