alunaro
Member level 5
- Joined
- Jan 15, 2002
- Messages
- 91
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Another world
- Activity points
- 770
eagle drill size
Hi
First, i'm hobbiest so i hardly could make tracks too much thin.
I'm trying to make pads diameter wider than default changing the restring params and others. The DRC but changes ALL pads in board, which is a problem with ICs (tracks can't pass in between pads). I tried to change pads directly in library with some scripts that i found in cadsoft site, but... these changes don't reflect on the board.
In resume, i need pads with 32mil of drill (0.8mm), 80mil of diameter (2mm)... but only in certain components (ie, resistors). For ICs, default package is ok.
Any idea? After 5 days I can't find any one.
Thanks
Hi
Thanks
