Chourizo
Junior Member level 2
Default incident power is 1W. How to change it? Maybe adding more wave ports with different phases?
What is the scale factor defined in the port?
Changing the scaling factor, you will change the power amplitude !Chourizo said:Thanks for the reply, Hash.
I can only change the phase, offset and scaling factor, but not the power. Maybe it´s because of using wave ports.
Can you please tell me. how can I find the impedance for the wave port, for which I have calculted my S Parameters.
