how to change exp. function like gaussian to linear funtion
eng.rana
Newbie level 2
Newbie level 2
how to linearized
I need to get linear function from exp. function " gaussian disterpution" (exp with x²), I need it for some application.
e.g.
f(x) = a * exp (- (x-u)²/b)
where a and b are constant
i tried to take the Log for the exp. function and then take the root squair for the function but dont now if this way is work and what about the f(x) , is also effect with log and root squair!!!!!! ,
and if i want to test it in which program would be help , matlab or other.please can you advice me for the solution.
thankx
Rana
Added after 21 minutes:
hi
here is what i tried to write it by matlab and I putted only one value for X,
but i need to enter 100 value and i have the data, what will be the change in for loop and i dont know if i am in the right way,
please i am waiting the reply
w = 0.2; PI = 3.141;
u = 10; x= 6.5;
y = 1/(w*sqrt(2*PI))*exp(-(x-u)^2/2*w^2);
z = log(y);
d = sqrt (z);
thankx
Rana
how do you change a function to log
Hi Rana,
I do not understand your problem.
Do you need a transformation such that a cumulative gaussian function becomes a linear function?
Regards
Z
gaussian function and linear function
Hi
anything can change or transfer the Gaussian function to linear it will be helpful.
Please if you have even an idea inform me as soon as possible, then I can try different ways to reach the goal of this work ( get linear function from Gaussain function)
regards
Rana
