Jenifer_gao
Member level 1
Hi All:
I am designing a low power OTA, in which a local CMFB technique is used to improve the GBW and SR without increasing power too much. The circuit is shown in the attachment.
GBW, and SR has been met by the introducing of two resistors at the top, but these two resitors also increase the second pole of this circuit, as a result the phase margin has been decreased significantly. A paper, "Simple technique using local CMFB to enhance slew rate and bandwidth of one-stage CMOS op-amps", suggests to add one resistor between the op-amp terminal and CL, as shown in my schematic, to provide a zero to cancel this pole. I tried this scheme, but I couldn't see any change. I doubt this resistor will introduce any zero, because it doesn't add another signal path.
If anybody can look into this circuit and give me some suggestions to compensate this second pole. Thanks in advance.
J
J
