How to call a method in class B from class A in C#?
islouis
Junior Member level 1
Hi:
I would like to ask some question about class in C#, my OO wasnt very good
i have a Class A, and Class B , what if class A require to have instance of class B, and class B need to call a memeber of class A, just 1 member, what should i do?
like the following:
public class A : other class
private B test = new B();
public void Amember()
XXX
and in Class B
i want to call the Amemeber() fm class A.. if i inheritance, i will get exception.
Thanks
Re: C# question
i work on Java but nevermind both are the same, so i guess you want to call a method in class B from class A the solution
you might make this method Amember() a static method (method = function)then you can call it by this way
A.Amember();
this will work, it also might work in other way but it depends on what this method do.
if this method job is to get some variable from class A you might use another way.
by passing the variable when creating an instance from B.
Re: C# question
Thanks for your reply
however, using static will caused another problem because Amember will call other funciton like listBox1.Items.Add(message), unless i make the listBox1 become static too.
I heard people suggest using delegate, however i have not success on that yet.
Regards,
Louis
Re: C# question
you said in your message (and class B need to call a memeber of class A)
what do u mean by member? is it a member varialble or kind of method ?
Re: C# question
Hi shebo
Yes, Class B will call have to call a method in Class A, which is Amember()
Class A
private B instance = new B();
public Amember(string)
listBox1.Items.Add(); //post
Class B
i need to call Amember here
thanks
