How to calculate Vth and Vgs in EKV model?
leonken
Full Member level 3
Full Member level 3
What is the equations for calculating threshold voltage Vth and gate-source voltaqge Vgs in weak inversion in EKV model?
thank you
Read the paper published by Eric Vittoz et. al.,
"An Analytical MOS Transistor Model Valid in All Regions of Operation and Dedicated to Low-Voltage and Low-Current Applications"
, Analog Integrated Circuits and Signal Processing, pp 83-114, Kluwer Academic Publication (1995).
https://legwww.epfl.ch/ekv/pdf/ekvpaper1.pdf
This is the novel paper used as main reference for designers working in subthreshold and ultra-low-power IC design.
This paper explains extraction methodologies for EKV
