How to calculate the toroid transformer ?
José Luis
Member level 3
Member level 3
toroid calculating
How can calculate the toroid transformer ?
Maybe this is helpfull :
hardcore
a sub L
Each toroid core has an A_sub_L value which is the inductance in mH for 1000 turns squared or nH per turn squared. You start out with the required inductance. Divide this value ( in nH) by A_sub_L to get the number of turns squared. Take the square root of the number of turns squared to get the number of turns.
Ferroxcube has a 950 page application handbook with all of the details for may ferrite transformers. https://www.ferroxcube.com/ select applications on the left menu and then the handbook link.
Toroid calculating
Here are docs for calculating toroidal transformers.
This is another article from Philips.
/ Warning #2 - Don't upload files from the net! Files deleted use links instead. /
Balun transformers
Finaly doc for Baluns
