how to calculate the thd of a pfc circuit
hanjingyu2008
how do you calculate the thd of a pfc circuit ?with filter or without?(Some chips say they can acheive 99% pf, do they include filter or without?)
For a TM/BCM pfc without filter, is 40% thd normal?
thanks
you always measure with the filter in place.
......though it may be useful to you to see the thd without the filter first so you can design the right filtration.
PFC's are stinkers for THD..............they cannot be heavily filtered as it would mess up the power factor....but then the high frequencies get into the mains.
By definition, THD designates harmonic distortion, which doesn't include PWM frequency components. In so far, it
shouldn't depend strongly on filtering.
According to IEC1000-3, harmonic currents have to measured up to the 40th harmonic at maximum. Even high power
PFC circuits would typically not emit PWM frequencies below 3 kHz. PWM conducted emissions above 150 kHz have
to comply with the respective EMC rules however.
If I only calculate the thd from 50Hz to 2kHz,
can the pf still be defined as 1/sqrt(1+thd*thd)?
thank you
does anyone know how to plot TDH waveform in Hspice? this might be helpful. THD in terms starting from 60Hz, 120hz, 180....
.tran (you time...)
.four freq ov
freq is your base frequency , and ov is the node you want to calculate the thd.
I know .tran and .four, but I dont know how to use them for me to see the Current at harmonic frequencies from the .NETLIST file. can you provide me the syntax...? I need 60hz, 120hz,180hz ....... up to the 20th.
1.Current THD is calculated by
I thd = √(I²+I³+....+Square of In)/I1
2.TM/BCM Pfc's current THD of 40% is normal without filter.
By proper filter and by the functionality of chips(to tune the inductor current wave shape nearer to zero crossing), even we could bring down to less than 2%
where did you get this calculation? can you give a reference for this? Thank you :)
maybe all the books about ic design
I know one from "cmos circuit design.layout and simulatiojn"
