How to calculate the output AC current?
ciyang
Newbie level 2
Newbie level 2
I find some circuit that put a inverter to be a buffer to supply multi-load.
In the case,10MHz Oscillator, I want use a inverter to meet this purpose.
But idon't know how to calculate output current?
I just can guess the oscillator can supply 2~3 loads,if over,put a inverter to supply more loads.
So,anyone can tell me how to calculate output current(AC)?
Thanks.
With Best Regards.
I'm not really sure about which type of inverter you meant... but regardless of the shape of the output current, you can use the following formula to calculate the Irms :
Irms = sqrt(sum(I(n)*I(n))/N), n=1~N (number of sample)
