how to calculate the opamp offest influence to the output voltage
shanmei
Advanced Member level 1
USA
Why the output voltage=1001 Vos? Thanks
It shows you right on that picture, VOUT=(1+Rf/Ri)*VOS
(because true VIN = imposed VIN differemce (GND) plus VOS).
The basic noninverting closed loop gain equation.
    shanmei
The figure is quite self-explanatory: Offset at the virtual ground -> non-inverting amplification of the offset -> G = 1 + (R2/R1) = 1001. Vo = G*Offset.
    shanmei
Do you mean the Vos applied to the negative input of the opamp, it is also equivalent to apply Vos to the positive input of the opamp?
--- Updated ---
But the offset is applied to the negative input of the opamp, not the positive input of the opamp
Due to feedback, the voltage at input(+) = input(-). Therefore, you can place Vos in either input, and the result will be the same.
