how to calculate the input impedance of this circuit?
katrin
Full Member level 1
Full Member level 1
calculating input impedance
Now I want to calculate the input impedance of a circuit, the input signal is a current signal, the circuit's input is composed of a complementary PMOS and NMOS common gate amplifier(M1 and M3)
M2, R2 and M4, R4 provide constant voltage bias for M1 and M3
If I want to do detailed analysis of input impedance, Vin/Iin, in other words, to derive the relation between Vin/Iin and the circuits parameters such like Gm, rds....
I think mainly I should consider about M1 and M3, but I am not sure if I can neglect the other components in the calculation.
I hope someone who is familiar with circuits analysis can help me with that, thanks.
calculate input impedance
If u can use spice then do AC analysis by connecting a AC current source at your inputs. Do frequency sweep. Normally your ac current source will be 1 A. so voltage at your input port is nothing but the effective small signal impedance seen at your input port.
This value will be much accurate than any other.
Thanks,
    katrin
input impedance calculation
For hand calculations you should consider M1, M3 and also R1 and R3; you will be able to neglect certain things depending on their values. The complete expression will be given by:
vin/iin = ((ro3+R3)/(1+gm3*ro3))||((ro1+R1)/(1+gm1*ro1))
if gm*ro<<1
vin/iin = (1/gm3+R3/(gm3*ro3))||(1/gm1+R1/(gm1*ro1))
Depending on the ration R/ro you will be able to neglect (or not) other terms.
Hope this helps,
diemilio
    katrin
how to calculate impedance
you didnt specify where the source of the transistor is. I am assuming the input port is connected to M1 and M3's source. In that case, your input impedance should be very small ( ~ 1/gm)
    katrin
how to calculate input resistance
As as mention before, this is true only if you can neglect the R/(gm*ro) term. If you can do this, then your impedance is NOT 1/gm, but (1/gm1)||(1/gm3), which (if your transistors are ratioed 2:1) will be 1/(2*gm)
diemilio
    katrin
can we find the input impedance of a cro from its minimum ferquncy and volteg value
