How to calculate the baud rate for UART protocol?
Mkanimozhi
Full Member level 4
Full Member level 4
How to calculate the baud rate for uart protocol, can i get detail description of this soon.and can i get any document to write my own coding in vhdl for UART protocol.
Regards
Kanimozhi.M
Re: baud rate generation
How to calculate the baud rate..?????
Let's assume that you are sending your data to PC at 25Khz after deriving a random freq from the master clock, but actually your PC cannot recieve the data.. because there obviously,will be a baudrate mismatch.There are some predefined baudrate values.. Max is 115.5 Kbps. This you can get from hyper terminal.
If you deviate very much from these values, PC cannot -sample the values and get synchronised. So the answer to your question is, decide upon the baudrate values you are going to use and calculate the freq accordingly.
-Shiva
    Mkanimozhi
use counter [ freq divider ] for the same
I need any good document for code my own VHDL coding for UART, that document should contain all the detail about transmitter,receiver and baud rate generation , can any one provide ,plz
Regards
Kanimozhi.M
Thank you, but i need the any document for to understand myself clearly what the internal operations and i need to design myself.
Regards
Kanimozhi.M
Regards
Kanimozhi.M
Hi Kani,
I guess itz very easy to design transmitter section first,to start with..
Just write some clock divider program to get a feq about 9500-9700..
And transmit a single character, for e.g. 'S'.
But for this I should know something about RS232 protocol..
Just refer this..
https://www.wcscnet.com/Tutorials/SerialComm/Page1.htm
Otherthan this, u dont need any document...
Just try..U can... :)
All the best..
-Shiva
How to calculate the baud rate for uart protocol?plz any one can explain in numerical?
Thanks in advance
Thanks in advance
Simple..!!!
[1/T(startbit-stop bit)]*10- if you have only 8 bits of data(i.e. no parity bits)
Ciao,
Shiva
Hi ,
it's very simple
system clk frequency/ur baud rate value
and the answer which we are getting here divided by 2
eg,
system clk=20mhz
baud value=9600
so
20mhz/9600=2083.33
now 2083.33/2=1041.66
so ur ciunt value is 1041 and
write the clk divider code for this count u will get the clk to synchronize the two systems.
Regards
Kanimozhi.M
hi
extacly correct but trans its ok, recevi , you have to div it by 2
