princerock
Junior Member level 2
I'm designing an op amp and want to calculate the HD3. The input signal is 1KHz. I found that there's a "dft" function in the calculator. But how to set the variables in it? ("from", "to" means what?) And how to get the HD3 from the dft result?
btw: how long should I run the transient simulation to calculate the HD3?
Thank you for your help in advance!
