hemnath
Advanced Member level 3
I have a pressure calibrator and I opened to check the sensor. It is Meas sensor 89CV.
On the sensor datasheet, its temperature data's are,
But in their product datsheet, it is mentioned as,
When I try to calculate using sensor datasheet,
Could you please explain how to calculate temperature coefficient and temperature effects?
Temperature Error – Span -1.0 %Span
Temperature Error – Zero - 1.0 %Span
Thermal Hysteresis – Span ±0.05 %Span
Thermal Hysteresis – Zero ±0.05 %Span
Compensated Temperature Range -20 +85 ºC
Temperature coefficient ± 0.005% of reading / °C with respect to 20°C
Operating Temperature 0 to 50°C
Calibrated Temperature 20°C ± 2°C
Calibrated Temp. Range 0 to 50°C
Storage Temperature -20 to 70°C
Temperature Effects 0.001% of reading /°C between 0 to 50°C
Is this calculation is correct for calculating temperature coefficient?1%span = -20 +85 ºC
1% span = 105ºC
1 ºC = 1%span/105
1 ºC = 0.009% span
