[SOLVED] How to calculate Stack size?
amayilsamy
Advanced Member level 1
Chennai,India
Hi All,
I want know how to calculate the stack size for the one program
Thanks to all
Just see the compiler's log after build your program; at least with gcc it is possible, so I would guess there is the same feature with others.
Hi thanks for the reply.
Is there possible to calculate after writing..?
I would not say 'calculate' once you are in a program scope, but rather to say 'simulate'. You can do it by your own, manually taking note of the result of execution of each instruction on your code seeing how many Call(assembly) were made with no return, line by line, step by step; good luck.
