[SOLVED] How to calculate/simulate/find out the output impedance?
palmeiras
Full Member level 6
Full Member level 6
South America
How to calculate/simulate/find out the output impedance? Basic question
Hello guys,
The usual method to measure the output impedance of a circuit modeled by a VTH and RTH (Thevenin equivalent), is to measure the output voltage under two conditions: (a) without load (open condition) and (b) with a known load (Rload2)
The output stage of my circuit is a CMOS source follower with a resistor load (Rload1). Then, if I connect a second load (Rload2) in order to measure the output voltage, I'm going to decrease the RTH because the bias current will be changed.
So, how can I measure the output impedance if RTH is a function of RLOAD?
thank you very much,
Use an AC test voltage and isolate your load with a capacitor. This way the DC working conditions are not upset. Select the capacitor so that at the test frequency, its reactance is very much smaller the the load impedance.
Frank
