yie
Newbie level 2
I have some problem about how to calculate power for my system. i use water jet as prime mover to move the turbine. Here i give the spec of my system :-
Water Jet spec
1. Operation pressure = 40 bar
2. Suction Volume = 17litre/minutes
We know that to calculate power is equal H(head) x flow rate x g x Efficiency...But for my system i don,t know the best way to calculate power. If i used this spec to calculate power, the result that i get is to small. So hope you can help me to simplify this problem. Thank you.
Water Jet spec
