edafisher
Junior Member level 3
When using Hspice, the simulation report gives this data:
**** voltage sources
subckt
element 0:vagnd 0:vvcc
volts 0. 1.900e+00
current 0. -1.528e-05
power 0. 2.903e-05
here vcc is a voltage source. i just wonder what does the current really mean here. since through the .meas measurement, i found this current equals neither the avg current nor rms current, and its value is less than both of them. could anyone tells how is this current calculated, could the power showed here used as the "power dissipation".
futher, how do you usually calculate a "power dissipation", i'm a little doubted of the power, and rather prefer to use voltage multiply the avg current as power dissipation.
subckt
volts 0. 1.900e+00
power 0. 2.903e-05
