how to calculate phase noise in spectre tool
us1710
Junior Member level 3
phase noise spectre
i have designed a VCO of ring oscillator type, but don't know how to calculate phase noise in spectre tool.
thnx in advance.
spectre phase noise
Run PSS and Pnoise analysis.
PSS is periodic staedy state. It calculates VCO operating frequency in steady state and Pnoise calculate the phase noise for the defined frequency range.
yes, you can run pss and pnoise.
more example you can find the openbook of cadence: Spectrerf
ring oscillator phase noise spectre
Yeap run a PSS+Pnoise simulation, you must run the PSS together with Pnoise and set the guessed foundamental frequency of your oscillator, set the harmonic to 7 or higher, set the initial time to 100ns or higher.
how to calculate the phase noise from frequency
Hello,
Here i uploaded file .how to perform PSS and Phase noise anlysis.follow those steps
in harmonic balance you can apply noisespect to calculate phase noise.
Re: how to calculate the phase noise from frequency
Hello,
can u please upload the file to perform pss and phase noise analysis in cadence
thanks in advance
