Palpurul
Member level 3
Hello, I've been trying to calculate the parasitic capacitance(end-to-end not pad to ground) of resistors from |z|/R graph that is given in some of the resistors' datasheets. Here is how I calculate it. I use the following circuit to model the resistor. I measure the input impedance of this circuit to ground. This model is also used in the datasheets( datasheets are shared below).
When I simulated this I discovered that at approximately |Z|/R = 0.7 frequency is f= 1/(2*pi*R*C). In this document http://www.farnell.com/datasheets/6370.pdf for internal impedance (end-to-end) for 0402 flip chip is given by 26.2 fF with that much capacitance according to my calculation for 1k resistor the |Z|/R graph should hit 0.7 at around 6 GHz but in the datasheet 0.7 crossing is between 2-3 GHz. What am I doing wrong here?
I am trying to calculate the capacitance of the resistors in this document : **broken link removed**(Fig.4 0402 components)
I calculate around 31fF (0.7 crossing around 50Mhz for 100k applying C=1/(2*pi*R*f)) , but I am skeptic about this because I am not sure if I am doing it right.
Thanks in advance.
Thanks in advance.
