avin11
Newbie level 5
When a netlist is extracted for a layout, what does the parasitic capacitances represent? Please check me on this:
- for input caps, it doesn't contain gate cap. but contains all routing caps for that input. When simulated in HSPICE, the gate cap is calculated by the tool and added to the extracted parasitic cap. to form the total node cap for that input node. Is this true?
- the parasitic cap. for other nodes are composed by diffusion caps of drains and sources connected to that node?
- i notice that HSPICE tends to recalculate the diffusion caps for the nodes
again and then adds these calculated values to the corresponding paracitic caps of those nodes to derive the net nodal cap. This would mean that the diff cap. is calculated twice, once by HSPICE and another from the extracted parasitic cap, and thus not accurate. Is this true?
Can anybody please comment on these statements? I'm quite confused about the net nodal caps that are gained from HSPICE. Can anybody also tell me of the HSPICE commands to check the individual components that make up a selected nodal cap? I'm currently using .OPTION CAPTAB to obtain nodal caps.
Thanks.
Thanks.
