how to calculate Jitter in spectre
sprinter
Newbie level 5
Newbie level 5
Jitter of a vco
I'm trying to measure the phase noise of my CMOS vco at 8GHz. I get pretty decent phase noise curve at higher tuning voltages (i.e. lower capacitance value) but at lower tuning voltages the drift is too much to make a decent phase noise measurement using a PSA.
NOw I want to quantify the instability at lower tune voltages by measuring the jitter. My questions are:
1. is measuring jitter the best way to judge the stability of the vco
2. If so, then how to measure jitter with a 6GHz LeCroy scope?
Thanks,
Adil.
Jitter of a vco
What is 6GHz the bandwidth or sampling rate pls?
If its a 6GHz bandwidth scope, & it will triggern_I think you can calculate/compensate for ca. 6dB/octave less amplitude...
K.
Re: Jitter of a vco
K.
It's the b/w. Could you elaborate further please.
Thanks,
Adil.
Added after 6 minutes:
biff44 said:
use a delay line frequency discriminator.
That's a good suggestion. I've not done it before but I'll try to find out more about it. IN the meantime I'm trying to get my hands on a signal source analyzer which has a reference source in quadrature & it locks the vco for a phase noise measurement. Anybody has experience with a signal source analyzer?
Thanks,
Adil.
