How to calculate Heat Dissipation in Main Switchboard
edinburgh
Member level 3
Member level 3
City of Angels
heat dissipation calculation
Dear Experts,
My friend is looking for a formula to calculate Heat Dissipation in Main Switchboard.
Pls kindly share and explain the calculation if you know.
He said he doesn't want to use IEC 890...!!!
Thanks.
BEst Regards,Edin
calculate heat dissipation
what is a switchboard?
how to calculate heat dissipation
well, calculating heat dissipation is one way to go. Measuring another way. If you have a complex board and it will go into production, you need to measure many. mesure the worst case. analyze the statistics. And then you'll get the picture.
I have always tried to calculate before the first protos arrive the heat disspiation. I have noticed that the more complex the board the bigger the calculation error from measurement.
If you do not have any power outputs, then measuring the input power (voltage * current) gives you a very good understanding of the heat that needs to be dissipated. After that look at the PCB with a thermal camera and you'll get the picture of what needs cooling.
