[SOLVED] how to calculate gate resistance of a mosfet
nishanthpv
Junior Member level 2
I am using umc 180 nm technology. sheet resistance of poly is 8 ohms/square.(it is written so in the technology file). for a 1u length and 1u width mos transistor (fingures=1), what is the gate resistance?(I don't know what is meant by /square)
Thanks in advance,
Nishanth
per square means per square micrometre. For, 180nm, gate resistance is simply Area in um x 8 Ohms. For a width of W and Length L in lambda it would be (W*L*0.18*8)
Your 1u/1u transistor is one square but to this you have to
add the gate contact tab geometry and gate contact
resistance terms. You should draw out the layout and pick
off the L and W, squares = L/W.
Now within the FET the resistance is distributed and so
is the Cdg/Cgs. Your L is from one point to another, and
picking the right ones is key. I would (always have) take
the channel center as one point and the inner edge of
the gate poly contact as the other.
RF FETs often are contacted at both sides so you'd do
that and then figure the parallel resistance-to-center.
