How to calculate breakdown voltage of capacitor?
ex4
Full Member level 2
Full Member level 2
Jakarta, Indonesia
hello
I want to calculate breakdown voltage of a plate capacitor. I only got info on the dielectric constant, the plate gaps, and the plate wide area, is it possible to calculate it using that information?
Basically, when you exceed the rated voltage, as with any other rated component, the capacitor can't handle it and the dielectric will probably melt or something, and cause a short circuit between the plates. This is the only thing I can think you mean by "capacitor breakdown". The other use of the term "breakdown" in electronics is for breakdown voltages in diodes.
For capacitors in series, 1/C[total] = 1/C[1] + 1/C[2] + 1/C[3] +...
For caps in parrallel, C[total] = C[1] + C[2] + C[3] + ...
The current and v0ltage are related by i = C(dV/dt), which are just derived from the equation Q=CV.
The rated voltage for the capacitor will be on there.
If its an electrolytic capacitor, you might wanna ramp up the voltage on it, for fun, and watch it explode!! :)
hehehe
i mean i want to calculate the breakdown voltage of my home made plate capacitor for the watercell fuel based on that info
