[SOLVED] How to build a ramp signal equation?
talking
Member level 2
Member level 2
I need to set a ramp equation: y-axis is h(t), and x-axis is t (=time).
So I think of two different equations for this.
(Equation1)
h(t) = a1 * t
where a1 is a slope (or gain), and t is time.
(Equation2)
h(t) = a2 * u(t)
where a2 is a slope (or gain), and u(t) is an unit function.
Which one is correct to express a ramp signal? What's the reason for it?
Thanks.
the first one is correct and to be practical
h(t) = a1 * t where t>=0 ( there is no time less than zero )
Thanks, Mahmoud. Could you please explain the reason why the second one is not proper?
Thanks.
mmmmm i think the attached photo will explain it
in the first situation function = u(t)
it is only a step function which will equal 1 for all t >0 and zero otherwise
in the other figure
function = a2 * u(t) where a2=5
then the function will equal 5 for all t >0 and zero otherwise
i hope u got it ......sorry for the hand drawing figures
I'm sorry for typo in Equation2. I missed 't' which needs to be multiplied by u(t) as follows.
(Equation2)
h(t) = a2 * t * u(t)
In this case, which one of equation1 and the above updated equation2 is correct for a ramp equation?
Thanks.
The first equation represents a ramp starting in time from -infinity going to +infinity. The second equation is the same ramp (if a1=a2) but time limited from 0 to +infinity; in this case h(t)=0 if t<=0.
Usually real signals are starting from 0; think, for example, at a circuit that is switched on at a certain time instant (this is t=0).
Thank you both. It is clear!
